I am in need of some help with speaker advise for a small home cinema room setup using a 2000w 2 channel amp (1000w ea channel). I have the projector, amplifier and comfy seating I now just need me speaker set up! Ideally I would like tower speakers BUT am unsure of how the ohms work in setting up and as I have inly 2 channels i have to be careful not to overload my amp by doing something stupid. The amp runs 4 ohms and 8 ohms. I have researched a set of tower speakers at 600w max ea 4 ohms. Can I run 4 of these from the 2000w amp without destroying sound or the amp?? I know a very small bit about parallel and in series but not enough to give it a try or brave enough to try should I say. I could go out and get a home theatre system to make things a lot easier BUT I need to use my 2000w amp and not waste all that power wattage. Any advise will be great
and thanks
and thanks
