nopiano
nopiano said:I don't recall seeing this useful video about cables on these pages before. Everything becomes clearer, and funnier, if you watch it!
https://www.youtube.com/watch?v=3UQDTZcpsDE
BigH said:Waste of time, if anything can cause phase problems
Nu2WhatHIFI said:Most systems simply don't have the resolution for many to hear the differences.
Nu2WhatHIFI said:"What are the technical reasons why two well made cables of the same thickness could possibly sound different?"
Numerous. There are several technical reasons to consider good cabling in a system. I've adopted these suggestions from an article that I read several years ago and it has served me well:
-good quality connectors
- good quality conductors regardless of the material used
-good qualty dielectrics! (not insulators, although good dielectrics do provide some insulation)
-wire geometries that make "sense"
-craftsmanship/care putting the wires together
The keys are the care taken putting it together and using appropraite geometries and materials to make a suitable cable. Almost all cables are made either to spec or from off the shelf cable and connectors. What can alter the sound? The first is to recognize that a cable has inductance, capacitance and resistance. Any two create a filter. So all cables filter to some extent. The dielectrics used are also important. They perturb the E field associated with the signal carried by the conductor. The dielectric that perturbs the least is Teflon. So often premium cables have a Teflon dielectric/jacket. But a caveat: if you cannot hear the difference yourself, don't bother. and th materials for the conductors? to me it makes sense to use silver tinned copper, silver or copper. All can have a different effect. But if using a particular conductor in interconnects, all the cabling needs to be the same sort of cable (all copper, all silver plated copper, or all silver) throughout the system. I know many here will laugh, but it does make a difference.
I am not in the industry, but have made my own observations. Most systems simply don't have the resolution for many to hear the difference.
RobinKidderminster said:Which nae sayers have had their imaginations caught by this over-priced snake oil cable? 🙂
andyjm said:Now as for the 'you need an expensive system and sophisticated ears to hear the difference Sir' - this is the classic line from a salesman just before he tries to sell you a bi-wired solution.
Part of my job as a subsea engineer involves spec-ing cables for subsea control umbilicals. If the cable spec isn't right signals don't even reach the end of the cable. That's called attenuation. To compensate, signal baud rates were, in the past, restricted to as low as 900. Fine if you're just sending "valve open / valve close" commands but not good enough at all in these days of multiphase flow meters, smart wells, etc. The electrical engineers I work with go to ridiculous lengths (like 50km) to spec the cables.abacus said:Benedict_Arnold said:Different alloys. Different wire drawing processes, which effect the crystalline structure of the wires. In a multistrand cable, the number of strands, the lay pattern, lay pitch, lay tension. Use of different materials for inner and outer strands. Hollow or plastic cores around which the conductors are wrapped to maximize skin effect. Different insulation materials with different dielectric parameters. All of which effect the impedances of the cables, which are frequency sensitive. Next?andyjm said:gasolin said:why?
From the whathifi review
The Hyper 2.0 is a class-leading speaker cable that sounds superb
Rather than have me run through (again) all the technical reasons why two well made cables of the same thickness will sound the same, lets mix this up a little for a change.
You say you don’t work for Chord, but your descriptions are typical of what they come out with, however what they don’t tell you, (And neither have you) is that none of it makes any difference to the sound in the audio band that everybody listens too. (Once again the descriptions are just a con to target the gullible, which anyone that remembers their elemental science classes can see through right away)
NOTE: If you can provide verifiable scientific proof that the details you mention do make a difference in the audio range, then please post the links, as I am always open to any verifiable scientific evidence that can be provided to challenge current scientific knowledge.
Bill
BTW: Bi-wiring is also a load of twaddle, plus the links provided by the manufacture will normally have a much greater CSA then the cable used to connect the speakers to the amplifier, so changing them is a complete nonsense. (Unless of course you can provide verifiable scientific proof)
Benedict_Arnold said:PS.
I wouldn't put any trust in blind tests either.
Most are done using undergraduate Millennial "lab rats" raised on iPods and earbuds, laptop speakers at best. Like sticking you or me in Lewis Hamilton's Sunday drive, they couldn't tell the difference between a $50 Argos special and any high end system you care to mention. Especially since they're given preselected music to listen to and only five or ten minutes per cable. Not exactly being able to sit down and mull over a full CD, the same CD, at least half a dozen times, listening for the nuances that make all the difference. Hence the results, and hence (I believe in part at least) their enthusiasm for the vinyl revival.
Gaz37 said:Benedict_Arnold said:PS.
So you're suggesting that because I'm not a racing driver I couldn't tell an F1 car from a Ford Focus diesel?
The difference would be obvious immediately, as should the difference between £100 per metre cable and £1 per metre cable to anybody who isn't deaf.
The fact that expensive cable does badly in blind tests isn't because the subjects don't possess the audio equivalent of F1 driver skills, it's because the cables are a rip off.
