- Aug 10, 2019
- 2,556
- 5
- 0
HI,
My system for hifi consists of;
CD - Roksan Kandy K2
Amp - Roksan Kandy K2 Integrated
Interconnect - Van Den Hul D-102 III
Speakers - PMC GB1i
Cable - QED silver XT anniversary (bi wire, 2-4)
I am thinking of upgrading the speaker cable and possibly the interconect (i have another use for the van den hull if I upgrade so won't be wasted)
I've noticed some second hand chord signature interconnects and speaker cable on ebay and also some nordost stuff (flat something or orther, one of which was gold - don't know much about this make. but have noticed it mentioned on here a few times)
If I go for new, then unless there would be a massive difference I think my budget would stop at around £500 ish for the cable (2x 2.5 or 3m prefereabley 2-4 biwire) and possibly similar price for interconnect. So possibly something like chord epic super twin - any views on that cable?
What do you guys reccommend? Also with the setup I have, I would like something I can keep so even if upgrade the other parts of the system the speaker cable and interconnect will be ok.
Any advice appriciated.
Thanks, Dan.
Speakers - PMC GB1i
Thanks, Dan.
