Speaker cable for boston A26 and audiolab amp
andyjm
15
Rethep said:
Just thick stranded copper wire, as short as possible, will do the job!
Good luck!
Yep, good advice indeed.
The following link is to a good quality, tested, 2.5mmsq 'shotgun' speaker cable. I have used it extensively and I can recommend it. It is effectively QED 79 strand, which used to be the bellweather speaker cable until marketing was discovered by cable manufacturers.
http://www.tlc-direct.co.uk/Products/CASPEAK79.html
andyjm
15
gasolin
Broner said:
Do you think that this combination will be more to your liking than the Adam A5X's you currently have?
Not shure (that's why i always buy from stores where i can return it), the amp costs without discount the same as a set of Adam A5X, bostons are a bit more expensive then the Q acoustics 2020i and dali zensor 1 even with the discount i am getting.
I am not 100% shure which amp is best for the speakers i like and the same goes for speakers i don't know the best speakers for the amp i like.
That's why i offen go crazy when i want to upgrade something, i ask and ask until i now what to get, just hard to know if it's somthing you like until you have used it for many hours with the music you like in your home
Have returned the Adama A5X
