Speaker Cable and interconnects
Hi there, I Have just bought on What Hifi 5 star ratings
Yamaha AS 500 Amp
Marantz CD 6003B CD Player
Dynaudio DM 2/6 Speaker
Interconnects i already own are Chord Chameleon Silver plus
Was thinking Chord Carnival or Qed Silver anniversary or XT Fully terminated with Qed Airlocs
Any advice would be great
Plus a Usb DAC
was using a Beresford 7510 Basic but wasnt impressed
Was Thinking Kingrex UD 01 Pro £249 . MF M1 DAC .£300
Thanx Chris
07791989633
Just straight to the point answers please no confusion
CnoEvil
556
14
The two makes of cable I like, are Atlas and Telurium Q.
Of the two dacs you mention, I would choose the MF - but as in all advice, please listen for yourself.
T
the record spot
If USB playback's important, then Emotiva's XDA-1 upsamples to 24/192khz while most others go up to 16-bit only. Item Audio can do one on home demo - expect to apy around £350.
The MF M1 DAC is nearer £400 unless you've found one on a deal somewhere. Its USB I think also only does 16-bit, so do check.
idc
1,142
117
19,370
Keep th ICs you already have, changing them will not make any difference. Get the DAC which has the most features you will use.
The Chord interconnect is a good one so I agree that it may be worth keeping
However if you feel that you do need a change I can highly recommend the Chord CobraPlus interconnect; superb sound with that and one that your amp and speakers would lap up.
As for speaker cable; the QED Silver Anniversary is good but it can be bettered by the Chord Carnival Silverscreen. If you want to go up from there, the QED Revelation or Chord Odyssey 2 speaker cables are superb
