Speaker Cable Advice QED Silver Anniversary upgrading to Kimber 8PR
Hi All
Hope all is well
My system is as follows
Proac Studio 140 driven by Musical Fidelity A3.2 Pre/Power Amp - Source Musical Fidelity A3.2 CD player
Currently using QED Silver Anniversary biwiring
I find that the music can be too overpowering in the base - would Kimber 8PR solve this ?
Just looking for simple upgrade in quality
before buying new cables, try moving the speakers further away from the wall (or closer)
abdulk_786:
Hi All
Hope all is well
Wow! Impressive speakers. As a matter of interest, what flooring do you have? Do you have any solid surfaces near them that might accentuate the bass? Are they standing directly on the floor?
JoelSim:
QED SA isn't a bassy cable, if anything it's a bit bright.
I don't think the cable is the problem.
^^^^What Joel said^^^^
You could try some new interconnects. My Kimber Silver Streaks also have a slightly leaner than neutral balance.
If anything QED SA is lean, so the bass will not be coming from that.
Do you have your speakers in the corners of the room, or right against a wall either behind or to the side.
As the other person said, have a play around with various positions for your speakers.
QED doesn't do it for me. Matbe better speaker positions and a better cable would help, maybe...
Big Chris:JoelSim:
Chris, you have been away and come back looking like one of He-Man's friends...
I had the MF A5, I found this amp was too overpowering bass wise, had to get rid as I couldn't listen very long before fatigue set in.
JoelSim:Big Chris:JoelSim:
He does a bit doesn't he.
Thanks a lot guys but what I want to know is will upgrading to Kimber 8PR make a huge difference - is it wise to do ?
As usual any help is more than appreciated - Cheers
