space needed room for the monitor audio RX6 performing well .... please help me!
I am about to buy the RX6, but my room is 3 meters by 3 meters. (about 10ft by 10ft).
this will be enough space for RX6 act? taking into account the
resonances of the low frequencies and everything which spoils the pure
sound?
please help me. to your views and your experiences are very important to me.
thank you very much
I've spent some quality time with the RX6s as well as the RS6s. I think your room is a little tight, but if you use the port plugs in the back and keep the speakers at least 18" out from the walls, they will sound quite good.
However, I personally would consider the RX2 on stands for such a small room. Still fanstastic sound with good low end punch. You'll save a few quid and they will work better in that small room.
BTW, the whole RX line is fanstastic value for money. Great choice.
galinhamix:I am about to buy the RX6, but my room is 3 meters by 3 meters. (about 10ft by 10ft).
sound?
thank you very much
I think your room is too small for them, personally.
I have a pair of RS6's in a room measuring 11ft x 15ft.
Even with the bungs in, the bass is a little boomy when the speakers are close to the wall.
Moving them 12-18" away from the wall improves the sound.
What jaxwired said. I have a pair of RX6s, I think your room is a bit too tight and that you'll get a better sound from the standmounts.
tractorboy:What jaxwired said. I have a pair of RX6s, I think your room is a bit too tight and that you'll get a better sound from the standmounts.
what are they like TB? Worth chopping in my RS6s?
Thank you all for your advice and opinions ...
to choose between the following standmouts, which would advise you all? between the MA BR2 / KEF IQ30 or BW 685?
and between BW CM5 / MA RX2 or Focal Chorus 807V.
and for other models Floorstanders, you would advise others to the size of my room?
in town where I live in Portugal there is no shops where I can listen
to before I choose, so I'll have to choose by ordering through the
review or your advice / opinion ....🙁(
for AMP was thinking the new CA AZUR 650 ...
very grateful for your attention! all the best for you, and excuse my bad English
Gerrard: I haven't listened to the RS6, so can't really say. I'd be surprised if the difference was significant enough to make it a worthwhile upgrade though. RX8 maybe?
Galinhamix: It's a bit of a tough one if you can't audition, but I'd stick with standmounts over floorstanders with that room size. Buying blind, I'd be tempted by either the 685 or the RX2 to match the CA650. Don't know anything about the Focal Chorus. Hopefully someone else will be along shortly to offer advice.
galinhamix I am also from portugal Lisbon.between the standmounters id go for the iq30.also one of the cheaper ones here.focals are very good also
this will be enough space for RX6 act? taking into account the resonances of the low frequencies and everything which spoils the pure sound?
thank you very much
What is the room acoustics like? do you have hard floors or carpets? soft furnishings and bookcase(s)? Like the others say, strictly speaking, your room is a tad too small to make the most of floorstanding speakers, but my room is 18' x 13' and my RS6's sound fine. We have carpets + sofa, armchair and a bookcase - these do tend to soften any low-end boom.
Focal speakers would be perfect with your amp, but the only model I've heard is 714's, which are....yep, you guessed, floorstanders.
