Soundbar or 5-1 seperates if sub needs to stay in a cupboard
julianhay
Should I go for a Soundbar or 5-1 seperates if sub needs to stay in a cupboard..?
ie Sonos (no sub needed), or 5-1 DOMES
Many thanks Julian
Tarxman
64
Hi Julian,
I think you'll find Yamaha actually design a number of their soundbar's with the idea that the sub will fit on a shelf in the cupboard. Understand, this is not a good place to put it for maximum performance though.
julianhay
problem is the configuration of the room means only cupboards and floor + have 2 young kids that will use the sub as a playground ride!
farawaydave
60
You dont mention a budget.if you can stretch I went for the sonos playbar fantastic piece of kit.When i could afford it i added the sonos sub and wow!! Beauty about the sub is its so easy to set up that when not in use just keep it in the cupboard...Simples..
fr0g
445
If you get a downward firing sub, that isn't a problem...Been there, seen it bought the T-shirt :)
Kids have been all over my BK XXLS 400 DF... It's built like a tank and they won't do it any damage... :)
jonathanRD
179
52
18,670
It could easily double as a coffee table or a seat - but in my house nobody is allowed to even touch it ! :)
Alantiggger
274
33
18,920
Try shouting (VERY LOUD ((WORKED FOR ME ))... NO !!! in the most sternest of voices whenever either go near it.... that should work.
Other than that, work on the parenting 'skills' (no offence intended mate).... get more mean, teach em both... right from wrong like :bounce:
AmigaNut
9
With my Wharfedale 9.1 & 9.0s I do not use a sub.
Set amp to say speakers are large and no sub, plenty umph bass for me.
Same goes for my Mission and Eltax set up in bedromm.
AmigaNut
fr0g
445
AmigaNut
That's fine if you aren't bothered about bass! :)
