Sound quality difference audio network players when using digital output
Peter v B
Hi fellow forum members,
Who can answer my question:
Is there a difference in sound quality between audio network players when using their digital output, using my external DAC?
Peter v B (NL)
abacus
376
127
19,070
No, the sound quality will be determined by your external DAC.
NOTE: All of them will have different features and differ in the way they operate, which should always be taken into consideration before purchase.
Hope this helps
Bill
Peter v B
Thanks Bill,
Your answer does help.
I thought there might be a difference in how good a player "translates" the music file into the digital audio output signal.
Being very happy with the sound of my DAC, I am thinking of buying a Hama DIT2000 network player, because of its price and positive user reviews: easy to use, good display (Instead of a Pioneer n-p01). It should replace my old Noxon Audio 2 network player.
I mainly use it to play music from my NAS and a few Dutch network radio stations....
Peter
kemills1
Hi Peter,
I'm inclinded to believe the sound is manipulated in the digital domain. I've just read a review of the Moon Neo MIND (a dacless streamer) where this comment was made. Fans of Moon’s signature sound will be pleased with the tuning here: If the digital data isn't manipulated, perhaps WHF would like to elaborate.
cheeseboy
246
Who can answer my question: Is there a difference in sound quality between audio network players when using their digital output, using my external DAC?
Peter v B (NL)
it depends how that signal is presented to the DAC. In thoery if it's just passed through without any manipulation, they should all sound the same, however, if a player may have settings, or be set, to EQ, DSP etc it can and will affect how it sounds before it's reached the DAC.
kemills1
If you have something like Roon, that can manipulate the data before it’s even sent to the streamer over the network. It’s hard to know what your dac is receiving these days.
ASK THE COMMUNITY
