sound level meter or set-up mic.
beater
72
I have set my system up with both a sound level meter and the set-up mic supplied with the amp and get totally different figures, whitch one is better to go for.
RickyDeg
16
Personally that doesn't surprise me. You likely got Audyssey in your Onkyo and depending on the situation when you do the mic-measurements you'll always get different results, both compared to individual measurements and when doing it with a sound level meter. The mic is not really all that high-tec either so who knows how accurate it truly is? Not hacking down on Audyssey as I am myself a fan of theirs, but just saying.
Go with what sounds best. Nothing can judge the result better than you!
Evaluate and trust your ears!
michael hoy
I use both, use the amps auto setup to achieve the speaker distances and the use the meter to tweak the loudness of the speakers.
Set the amp to zero on the volume (that is reference level not no sound), use the manual test tone with the meter set at 75dB.
