- Aug 10, 2019
- 2,556
- 5
- 0
Hey All
I'm considering either one of the above. Are the only differences truely the FreeSat option on the W5810?
I've read a lot about backlight bleed and it seems you either get a good or bad one. What are the best tests to know you have a dud? Does it settle down and go away? Are the 5810s better as implied by the WHF review vs the older W5500.
I currently only watch SD with Sky + in UK but shortly moving to cable on Ziggo or UPC in the Netherlands. Would it be better just to get the cheaper W5500 from amazon for £650 or is the W5810 really worth £800?
The Sky+ devices always seemed to be one of the best PVRs around. Do others now make good models which compare and will do FreeSat as well?
