I use my Sony BDP-S790 Blu Ray player primarily to view video (AVI, MP4 & MKV) files from an external USB HDD but am getting increasingly frustrated by its inability to play the MKV files properly. If I just press the play button, everything works as advertised but as soon as I try to either rewind or fast forward, the MKV file stops playing and automatically goes on to play the next file on the disk. I had exactly the same issue with my previous player which was also a Sony (BDP-S390).
MKV files play, fast forward and rewind perfectly from USB disks plugged into my Samsung UE46F8000 TV and I am therefore assuming that they would also play OK on a Samsung Blu Ray Player and was therefore considering either a Samsung BDH 6500 or BDF 7500 as a replacement for the Sony and was wondering whether anybody has any experience of either and, in particular, could comment on MKV compatibility. That said, I am a bit put off by the fact that both of them only seem to have front USB input and any other suggestions would be much appreciated.
Before anybody suggests simply using the TV as the MKV player, it's OK as a temporary fix but a bit of a pain in the long term due to the numbers of buttons that need to be pressed when going between TV and paused video files.
Thanks in advance.
Thanks in advance.
