Sony TV - 32/37 W5500 - measurement required
Juzzie Wuzzie
437
244
19,270
Would someone who owns either of the above tvs (i.e. in either size) kindly measure the distance between the bottom centre of the tv and the rear HDMI sockets? In short, my HDMI cable is sunk into the wall (i.e. can't move) and I want to know whether there is enough of it extruding to support an upgrade to one or both of the above televisions.
Schoolboy error - but if you are sinking cables into a wall, makesure that either a) the length is adjustable (because you use a free flowing channel) or b) that you leave enough "slack" to allow future upgrades.
I've got the 37W5500 and I make it 38cm from the bottom middle of the TV to the rear HDMI sockets in a straight line. I'm sure you could get some kind of short extension for the cable if it's not quite long enough.
