- Aug 10, 2019
- 2,556
- 4
- 0
was wondering if some one who owns this recorder could help me out .
i can't get it to record from standby .
i was under the impression that you could set the timer to record and then put the recorder on standby , when its time for the program to start the recorder turns on , records the program and then turns off ???
mine will only record a program if its on and not in standby mode.
could be a setting i need to change but not sure .
any help thanks
Simon
any help thanks
Simon
