Sony Davis 10 mute problems.
Choucas
10
My Sony Davis10 was off for three weeks whilst I was away. On returning, I find I can't seem to get the audio system through the TV.
It tells me that the muting os on, but pressing the mute button on the remote does nothing when I was expecting to the mute to then be off!
Normally, I have to press the 'Function' button on the remote just twice and then the surround system kicks in, but it seems to scroll through a range of settings now.
I can only hear Sky through the TV audio and I have none for DVD. I have done the usual things like check cables, turn on and off to reset etc but no luck.
Help!!! |(
Thanks,
Graham
I was a bit confused by the title. I have heard of a Bravia, but not a Davis! I think you maybe have an AV system?
We have an old DAV-S5 (I think it is) and our remote stopped working on several functions. But maybe yours has a hard reset somewhere too - at the back maybe?
Sorry not much help. Hope you get it sorted, and maybe re-post in the AV section here?
