sony dav is10
help help help
I have just purchase this wonderfull sony home cinema system but have a problem my tv only has one hdmi port at the rear so how do irecieve digital sound/vison from my satelite receiver
I have currently conectect my system to the saterlite via a digital optical cord and then from the satalite to the tv via a hdmi lead do i need to connect this to a switch box then another hdmi lead to the tv and a futher hdmi lead from the switch box to the sony system WILL THIS WORK
or is the an easy or better way many thanks mark
Andrew Everard
1,878
Assuming your TV has two HDMI inputs, all you need is another HDMI from the DAV-IS10 to the TV to carry pictures from the onboard DVD player.
Only if your TV has just a single input will you need to connect the DAV-IS10 and the satellite box to the switcher, and then a cable from the switcher to the TV's input.
Thanks Andrew for your promt reply but can i just go over this again
my tv as only one hdmi port therfore i need
connect satelite via hdmi lead to a swith box also connect the sony system via hdmi lead to the switch box and finally with a further hdmi lead connect to the tv
then bingo hope fully thanks again
