SONY DAV IS10- Non Multi Region Impact
This DVD player is not multi region enabled and not every dealer has a hack for this except (have seen one only on Superfi). So would i be able to play DVDs which are region 0 /All regions on this player.
Info on this much appreciated
Your DVD , as you say, is NOT multi-regioned enabled, so it is likely to play only Region 2 DVD's. In order for it to play all-region or zero-region dvd's, it must be multi-region enabled.
There may be a hack code for this on e-bay. I got one of this before for my old dvd player and it worked.
thanks , what you say is correct and i have tested that out.
