Sony Blu-Ray players are they multi region
sargan
I am confused by adds for SONY Blu-Ray players, for example:
http://www.amazon.co.uk/MULTIREGION-BDP-S5200-BDPS5200-Blu-Ray-Region-Black/dp/B00KY51LK4/ref=sr_1_3?ie=UTF8&qid=1425423398&sr=8-3&keywords=sony+bdp+s5200+region
Typical ad .. states 'multi region' player, yet in the following sect states "Blu-ray players and DVD players sold by Amazon.co.uk play UK (Region Two) Blu-ray discs and DVDs only"
Are Sony players muli region or not ? or is this some get-out clause by Amazon.
Or is there some hack that has to be applied to make them multi region ... seen some hacks that require a one-time input of codes on remote.
BenLaw
475
7
18,895
jjbomber said:
..... whereas Blu-Rays are not.
Not true at all. DVDs are region coded whereas many / most blu Rays are multi region. Which are multi region and which are locked can be checked on sites such as blu-ray.com.
Players require a hardware mod to play blu rays from other regions. Most players do not come with this mod unless you buy from a specialist site. Players require a software mod to play DVDs from other regions. If the listing is not clear on this point you should enquire with the seller. Beware that U.S. DVDs may play in NTSC rather than PAL format.
Deleted member 2457
Most Blu-Ray players are multi-region today, you just have to check to see. Any problems make sure you can send it back like Amazon for example.
No, actually, most blu ray discs are multizone. Players are region locked for blu rays. This is a compulsory requirement as per BDA. They may be multiregion for DVDs but you should confirm before purchase.
Deleted member 2457
Thats what I was trying to say.
jjbomber
If you read down the Q&A on Amazon you would have found out the answer. He is asking about one specific model, not generally. Nobody likes a smartarse, especially when you are wrong!
jjbomber said:
BenLaw said:
Not true at all. DVDs are region coded whereas many / most blu Rays are multi region. Which are multi region and which are locked can be checked on sites such as blu-ray.com.?
I'm not sure what you mean. You said "DVDs are multiregion whereas blu rays are not", which is not true at all.
Edit: Ah, now I get it. You mean the player playing the discs, not discs themselves.
BenLaw
475
7
18,895
Ok, so you meant something different from what you actually said. Clarity is key. Nothing I said was wrong, unless you can point out otherwise.
Nepheler
12
I've not tried out much Blu-ray players but my 1-year old Samsung SE-506BB works smoothly so far. Got a French BD a while ago and Samsung reads it well.
BenLaw
475
7
18,895
Blu ray region B / 2 covers all of Europe (and Africa, the Middle East and Australasia) so it would be pretty bizarre if you couldn't play a French blu ray on a UK player!
chrisr1718
52
Check the Amazon ad again, it may be like this one:
http://www.amazon.co.uk/BDP-S7200-Blu-Ray-MULTIREGION-High-Resolution-Upscaler-Black/dp/B00KY5O75A/ref=sr_1_1?ie=UTF8&qid=1426773401&sr=8-1&keywords=sony+bdp+s7200+region
Like your example the ad .. states 'multi region[/b]' player, yet in the following sect states "Blu-ray players and DVD players sold by Amazon.co.uk play UK (Region Two) Blu-ray discs and DVDs only"[/b]
but it's Dispatched from and sold by magicdiscounts, therefore not sold by Amazon.co.uk
Hope this helps
