sony blu ray choice BDPS360 or BDPS550
1978scotty
26
Hi Iam looking to purchase a blu ray to partner my 32w5500 and the decision is down to BDPS360 or BDPS550. I want the best quality image possible and have been advised to stick with the same brand for tv and blu ray.
Advice and opions please
I wouldn't worry too much about the same brand - go for the best player in your budget.
However, I'm guessing your budget is around £200? In which case I would actually go with the BDP-S360 unless you need the mutlichannel outputs which are present on the BDP-S550 e.g. to connect into a home cinema amp which doesn't feature an HDMI input capable of receiving HD audio.
