I've a decode issue that hopefully someone has got some suggestions for ...
I've got the 550 connected to a Sony 2400ES amp. - HDMI (1.3), audio set to Direct, HDMI as priority, etc. I've got a 6.1 setup.
When I slot in a SD DVD such as Blade II, if I select the DTS ES track, the amp. says it's DTS ES, and the surround is fine. However, if I select the DD EX track, the amp. says that it's just receiving DD 5.1.
I slotted in SW - Revenge of the Sith, to check that one. When I play the movie, the THX logo is being indicated on the amp. as Dolby D EX, but then the film kicks in and the amp. shows DD 5.1
Pressing Display on the 550 during the THX logo shows Dolgby Digital 3/2.1, and the same during the film.
I'm assuming that it's the 550 at 'fault' here, given that the amp. correctly handles the THX logo, but ...
Any suggestions ?
Can someone try the same film on their 550, and see if they've the same problem ?
Any suggestions ?
