Sony bdp s370 subtitles in .vob file
kevinJ
51
I was playing around with my s370, trying to make a backed up dvd play from my usbstick. Video and audio is no problem at all, but the sony doesn't see there are subtitles inside the .vob files.
Does anyone know how to make the subtitles to play?
thanks
Kevin
kevinJ
51
Jeps, very sure there are subs. 6 different ones. I used dvdfab to put them on my usbstick, and didn't compress. And I can access them when using my tv without a problem (but the tv makes them very hard to read. LG tv btw)
I also noticed that .srt subtitle files will not show either, but subtitles inside a .mkv container are no problem. Strange.
aliEnRIK
92
Burn the vob file to disc to rule out of its USB specific. FAB should be fine so long as its not physically changed anything
kevinJ
51
Its definately usb specific. The S370 will not display any type off subtitle from the usbinput (except when that subtitle is contained within an .mkv file)
