Thanks for your reply. Don't think I'll be able to connect those Sonos to Node. Just wondering if it is worth going for the Node with the hi-fi as thought the sound might be better than a Port?I don't have either but I gather there are interoperability issues when trying to get Sonos speakers linked to a Node..
As you already have Sonos speakers I would think it better if you went with the Port.
Others, however, may have more experience than me in this department.
If you're building a new system or want to use the Node on it's own then that's the way to go for better sound quality.Thanks for your reply. Don't think I'll be able to connect those Sonos to Node. Just wondering if it is worth going for the Node with the hi-fi as thought the sound might be better than a Port?
I have the sonos port and i know that it has had some not so good reviews about sound quality but connected up with some descent cables and it seems to be fine to my ears . i have had no experience with the Node to give view about it.If you're building a new system or want to use the Node on it's own then that's the way to go for bet t sound quality.
Check this:First time post here. I’ve been a long time user of a Sonos Connect, streaming Spotify to my stereo system. Recently upgraded some components and tried the Node2i and Amazon HD. Yes, very noticeable sound improvement. I use the BluOS controller for iPhone/iPad. My personal preference is the Sonos app is just so much more enjoyable to use. So easy, intuitive and stable. BluOS app not so much for me.
Today I am streaming back and forth between the Node2i and the new Sonos Port OS2. Trying to decide which way to go. Streaming to an Electrocompaniet ECD-1 dac > VTL TL2.5 Pre > Odessey Khartago Amp > Kef r11s.
Node2i presents a smooth warm sound with tighter bass. The Port sounds more detailed, although can be a bit bright sometimes even a little harsh.
I’m exploring a better power supply for the Port and would be willing to spend a few hundred bucks because I enjoy the Sonos controller so much more than the BluOS controller.
Good luck with your decision!
