Solid Tech Racks
peter98
7
Has anyone here used Solid Tech racks? and can please share their thoughts on the build quality, and how they’ve impacted your setup? Could you please share your feedback?​
spl84
119
70
670
I've always admired them from a distance as they are wicked expensive. The "hyperspike" series are very nice. If I had unlimited budget I would love to have a rack or two.:cool:
spl84
119
70
670
Never had any set up that was even a little bit sensitive to set up, choice of supporting furniture other than when using a TT or a valve amplifier. I've had CD players, amplifiers on the floor without negative effect compared to putting them on racks.
Too much BS in Hifi as usual
Sitting your equipment on a stand is bs? Would never sit my equipment on the floor as it would open the door to all kinds of bad outcomes, but to each his own...
twinkletoes
Hasn't got to be expensive, Ikea for example but id never just set it on the floor. id end up booting it at some point.
Reactions: spl84
Anything directly on the floor has the ability to have beer thrown directly down into it.
It has happened believe me and it wasn't a pretty outcome.
If you have several pieces of equipment a rack is essential.
However the need for the quality of those the OP aludes to is pointless.
i would suggest that, depending on what kit you have, it needs to be off the floor with plenty of room for air circulation and if you have a certain type of turntable it needs a separate shelf probably wall mounted.
The Townshend Racks referred to earlier are excellent but completely pointless in a reasonably priced set-up.
The addition of a rack of this price into any system on a moderate budget is pointless.
Reactions: spl84
