And it is probably the best 20 pounds I've ever spent, besides the Chromecast audio.
My HT system always sounded a bit soulless and flat for music. I've just added the qacoustics concept centre speaker to my setup, and was still under whelmed with dynamics in music.
As a last ditch effort before plinking for a new AVR, I decided I would try the audyssey app.
My Lenovo tab's firmware didn't support the app, so downloaded onto my blackberry priv . It initially failed to recognise my marantz sr6011 on the network, had to enter the avr's ip address manually. Once done it kept dropping the connection from time to time. This certainly needs a higher degree of resolve than pockets to get it right. Once I got the connection working, I was asked to carry out the calibration again. I was under the impression that I could import the last calibration file into the app and tweak it there. However there was no option to import the last file so I went around calibrating again. And irritatingly it dropped connection a couple of times in the middle of the calibration too. After almost 4 attempts I completed the calibration, and then could see the individual speaker measurements before and after room correction.
Though there was the option to adjust the eq curve for each speaker individually, I couldn't figure out what to do there. And trying to tweak a curve by touch alone with my thick fingers on a small 5.5 inch screen was asking for too much. But I noticed that there were several humps in my speaker measurements upto 200 Hz. So I went into each speaker settings, and set audyssey correction only upto 250hz on all speakers. Then I exported the file to the marantz and sit back to listen. And I can only say wow. The missing life and dynamics in the music is back in full. I spent a full day yesterday watching music vids on YouTube, and I could swear I could be listening to a complete new system , and not just a different AVR. I usually listen in DTS neural x mode, and not once did I feel the urge to shift to my 2 channel rig.
Iam sure folks with knowledge of eq curves and room correction could extract more mileage from the app. But iam very happy with where iam. I would rank it as the 20 pounds that made me fall in love with my system again.
Will I try taking measurements again and tweaking for better results, hell no. The dropping connection is a royal PITA, I almost gave up a couple of times, but it was worth it in the end
