Snooker on HUMAX = Yuk!!!
roger06
374
Hi
I recently inherited a 2 year old Humax 9300T PVR. Generally the tuner is better than the one in the Panasonic TV – better colour and a more vibrant picture.
But when watching the snooker the motion is horrible. The white is worst with a 'tail' behind it most of the time when it's moving.
Is the HUMAX just not very good when it comes to motion or are there settings I need to play with? I am using the HDMI cable that came with it (to the receiver) so could that be the culprit?
I have the freesat equivalent and do not see these problems. I use the cable provided with the box ( I have tried an expensive cable and could see no difference).
roger06 said:
Could it be an upscaling issue? I think I've set the box to output at 576 and let the TV upscale...
Could be.
I also have the Freesat box, and *did* see exactly this problem when connected to a CRT TV via SCART at 576i, but when I upgraded to a Full HD plasma and used the HDMI connection at 1080i instead, the trails vanished.
I'd certainly try 720p and/or 1080i output if the box will.
daveloc said:
Could be.
I'll give it a go... no more snooker to test it with though!!
