Thought you said your budget was 500 Euros? How much is the Rega Io where you are??The phono input is a must, the bass/treble a desirable optional
I don't think he will get a new Sprout for his budget.ps audio sprout 100 (bass bosst at 70hz is always on) or look at a used Pro-ject MaiA DS2
€ 489,- and I'm in The NetherlandsThought you said your budget was 500 Euros? How much is the Rega Io where you are??
Then why is it "Sadly very much overof the amount of money I'm willing to spent"?€ 489,- and I'm in The Netherlands
As I said you will not get a new Sprout for his budget...... 😎
My bad, sorry. I was replying to the comment on the Luxman. Edited it. Thanks for the suggestionThen why is it "Sadly very much overof the amount of money I'm willing to spent"?
I see, thanks. I was a bit confused there.My bad, sorry. I was replying to the comment on the Luxman. Edited it. Thanks for the suggestion
I guess not but thought you were replying to my ' I don't think he will get a new Sprout .......' comment.Does it has to be new ?
New to me, brand new is optional, yet I haven't been able to find anything remotely suitable second hand around here...
It is a bit difficult to tell whether he is referring to the replacement amplifier or definitely means new as in brand new.....
I am on the lookout for one, looks like a good option. The ones I found with a quick look are way over budget thoughUpdate the sprout 100 didi cost only $599 in 2018, why has it become so much more expensive, over $1000
PS Audio Sprout100 integrated amplifier | Stereophile.com
The original PS Audio Sprout, which I reviewed in the May 2015 issue, showed newcomers an easier, smaller way to amplify music recordings in the home. At $599, the Sprout100 costs $100 more. It fixes a few of the old Sprout's weirdnesses: no power-on indicator light, no remote control, five-way...www.stereophile.com
