Hello,
I have a Primare I30 and matching CD31 and I am using Russ Andrews Classic Powerkords to both with a Crystal H interconnect and Qed Silver Spiral speaker cable and a pair of Monitor Audio RS8’s. I am looking for significant improvements to my system and I think the best way to do this is to improve my speakers. I seem to be quite set on getting a pair of PMC speakers and I definitely want a pair of floor standing speakers of similar size to the RS8’s with an improved sound quality across the board.
I mainly listen to bands like Bon Jovi and Bryan Adams, but also I am a big fan of Iron Maiden and Guns N Roses, at the other end of the scale I listen to Enrique Iglesias and Ronan Keating and more recently I have been enjoying female vocalists such as Celine Dion.
My room is roughly 379cm x 320cm and 250cm high with an alcove on one of the walls which is 37cm deep and ruins room acoustics. I am aware that my current speakers are ideally a bit big for the dimensions of the room and I do have problems with bass. Initially I was looking at PMC Fb1i’s and most favourably a pair of Ob1i’s (second hand), the only problem is that from what I have heard both models have powerful bass and may be overkill in my room. Therefore I have also been looking at the smaller Gb1i’s and from what I have read it may be better spending less to gain more in this case.
Any advice on the PMC speakers and what may suite my system would be very much appreciated.
