For computer software one is always given the minimmum spec for running it. There is a minimum requirement and a recommended configuration. For example:
2nd-generation Core i5 (2GHz+), 3rd/4th-generation Core i5 processor, or equivalent;
Windows 7 or later
Might the same be done for CD and LP music? I believe it would be helpful and clear the air regarding the quality of Hi FI
Minimum System Requirments:
(room size, listening position specified, 3 metres away from speakers, for example: amp specified for a specific listening area)
Amplifier Specs: Power, THD, SNR, Crosstalk as mentioned in this guide.
https://www.cambridgeaudio.com/blog/amplifier-specifications
Speakers: Frequency response, sensitiviy, power handling (depends on room?). This is a guide to choosing speakers:
http://www.cnet.com/news/speaker-specifications-a-consumer-guide/
Windows 7 or later
