Serious question, for Andrew regarding the Naim HDX
fr0g
445
A serious question as you have actually listened to one...
Where does its performance lie in comparison to some of the best CD players? I was and still am pretty sceptical, but if it has performace levels of a £4000+ CD player, then I could and probably would change my mind. I still think it sounds rather under-specced, but does it really have this level of performance?
I have only heard the unit in demonstrations, where it sounded impressive. But I have yet to do some serious comparative listening in a known system/environment, and until then I'm not in a position to consider how it compares to conventional CD players - if indeed that isn't a .case of comparing apples and oranges.
Andrew Everard:
Fair enoough. I dont know why Apples and Oranges though... It essentially utilises the inherrent advantage of reading the contents of a CD from a HDD rather than a CD platter. So it ought to sound at least as good as a CDX2, and hopefully better.
I'd love to listen to one in any case.
Agreed about apples and oranges - surely the point is that it's a music source, and should be judged as such (irrespective of the medium), therefore comparison with other music sources is valid and important (especially given the huge cost).
JohnDuncan:Agreed about apples and oranges - surely the point is that it's a music source, and should be judged as such (irrespective of the medium), therefore comparison with other music sources is valid and important (especially given the huge cost).
The point I was making though, is it is the same medium... Digital playback of the contents of a CD.
Ultimately HDD playback is potentially far better than CD transport playback. It just depends on the implementation.
So if they (Naim) have done it correctly, then I would hope the HDD playback was at least on a par with their nearest priced CD player, and preferrably better (obviously allowing for the extra cost of parts, and development)
Yeah, agreed, the music is the same whatever format, so how good a job does it do at getting the music to you, irrespective of how it does it (vinyl/CD/HDD/8-track).
Yeah but no but - there's rather more to the HDX than just a CD player, so it might be unfair to suggest a direct price comparison is in order.
At this level, I'd be inclined to say that price is irrelevant, since I'd hope for however many grand it is that it's pretty much "reference implementation". Of course, if it sounds like a CD6002, then that's an issue......
. Not that I'll ever buy one, since I could do it cheaper with a Mac, a DAC and unlimited storage, RAID-configured however I like.
JohnDuncan:At this level, I'd be inclined to say that price is irrelevant, since I'd hope for however many grand it is that it's pretty much "reference implementation". Of course, if it sounds like a CD6002, then that's an issue......
It would be an issue if it sounded any worse than their £3000 CD player (on HDD format) for me, given that the hard drives will have cost under £100. I would take into account the extra development, screen etc, but IMO it needs to be outperforming the CD2X on HDD playback, to be worth consideration.
HDX -vs- CDP. Isn't it like comparing a DVD recorder to a DVD player at the same price? i.e. different functionality
HDX -vs- Macbook/Dac/etc. Isn't that like comparing a Arcam solo to seperates? i.e. convinience factor
jules.
jules153:HDX -vs- CDP. Isn't it like comparing a DVD recorder to a DVD player at the same price? i.e. different functionality
jules.
No. The HDD should be there in order to playback at a higher fidelity, as it is a far better playback mech than a CD transport.
I imagine thats what the idea is. £4500 is hardly 'convenience' territory...
I think it's a mistake to assume more than tiny audible differences between HDD and CD. It's agreed that CD isn't as good technically, but with everything in good order, differences will be difficult to hear.
The DAC determines the sound quality and all modern ones are relatively inexpensive and 24 Bit playing 16 Bit in the case of CD, so they easily exceed the requirement and are virtually indistinguishable from one and other if their Manufacturers' evaluation Boards are compared.
Basically you have to do what they tell you and if you don't the sound will be worse. Therefore there should be no audible differences between any of these devices and if there are it suggests mistakes in interpreting instructions, corners cut because of space constraints and or price point targets.
Ashley
Ashley James:I think it's a mistake to assume more than tiny audible differences between HDD and CD. It's agreed that CD isn't as good technically, but with everything in good order, differences will be difficult to hear.
Ashley
Totally appreciate that... My point is that the HDD playback should be at least on a par, if not better. And taking the price of the unit into consideration, it ought to be on a par with their nearest priced CD player.
fr0g:
And after all, all the company's done is sling in a hard drive. And how much is one of those...?
Andrew - I suspect that much of the cost is for software Licences.
Ashley
Ashley James:Andrew - I suspect that much of the cost is for software Licences.
Ashley
Just the point I was making - that there are more costs involved than might immediately seem apparent.
I just bought a HD music centre (MusicCast MCX2000)and very very please with the sound (through my DAC). I never ever thought I would go down this route but read some of Forums's posts make me made yet, another compulsive buy!
I could, of course, tell you many dedicated cd players, I used to own, that would out preform my present combo but then they are cost a lot more. As for transports are concern though, this is it....I am converted!
You can always make you own! http://www.mini-itx.com/2006/10/02/the-dos-head-unit
This is a most interesting site for small format PC motherboards, they are very energy efficient and often don't have noisy fans. It's worth studying all the projects.
Ashley
fr0g:jules153:HDX -vs- CDP. Isn't it like comparing a DVD recorder to a DVD player at the same price? i.e. different functionality
jules.
I disagree Frog. The HDD in the HDX is there to give increased functionality - ripping CDs, storing, playing 96kHz files. It also has network functionality, Gracenote etc. etc. These extras are not designed to give better sound quality when playing 16bit/44kHz 'CDs'.
jules.
jules153:fr0g:jules153:HDX -vs- CDP. Isn't it like comparing a DVD recorder to a DVD player at the same price? i.e. different functionality
jules.
jules.
For £4500 it ought to be.
Thaiman:I just bought a HD music centre (MusicCast MCX2000)and very very please with the sound (through my DAC). I never ever thought I would go down this route but read some of Forums's posts make me made yet, another compulsive buy!
On a lighter note, great new Avatar shot, sir
Andrew Everard:
fr0g:
I mention their £3000 player. This unit is £4500 - I understand entirely that its more than 'slinging in a hard drive' (or in fact 2), but that £1500 ought to cover anything they've done... software licences, or whatever.
Again. I would like to hear it very much, although I am obviously not anywhere near its target market. I suspect it will sell to people who either don't have much computer knowledge, or the desire to have a traditional computer as part of a hifi setup...but it still needs to be very very good, for that premium...
I think this is one for die-hard naim fans that bought into their system philosophy and dont want to deviate from the concept. I'm sure as such will do well and sound good in the process. Whether this is good value at over 4 grand I doubt when you see what can be done for much less but then again, for your high end 'Naim'er' this will be of little consequence.
Don't get me wrong, I love my Naim amps and think my investment on them was highly worthwhile. But the thought of spending £4.5k on any source makes me shudder.
