Screen saver wobbling for Panasonic plasma TH-42PZ700
Hi
The instruction manual says the plasma has a screen saver, wobbling.
I cannot see any settings for this and I have not seen any screen saver appear on the plasma.
Does anyone have any information on this?
Thanks for any help!
Doron
Hi Doron
I have a Panansonic TH-37PX70 plasma, i should image the following applies to your set as well.
Panasonic have been very clever with this screen saver, its not like what you get on a PC when you leave it for a certain amount of time.
Every so ofton, how ofton i don't know but the whole screen moves about a couple of pixels left to right top and bottom, this movement is so slight the human eye does not pick it up.
But it does prevent pixels showning a certain colour for any amount of time, therefore eliminating screen burn.
But does that make any difference? I mean, if the image is moved by only a few pixels then isn't it likely that the pixels on the screen will still be displaying exactly the same thing?
