scart to component
Liamo50
28
I have a samsung ue 40 D6100 3D led smart tv and a oace sky box with only scart connect
what is the nest scart to component cable to work with my tv Thanks William a.
Liamo50 said:
I have a Samsung Ue 40 D6100 3D led smart TV and a pace sky box with only scart connection
what is the best scart to component cable to work with my tv Thanks William a.
You might as well just connect the scart to the tv - there will be no benefit in using a scart to component cable.
I'd strongly recommend getting a new skybox with an HDMI output. With only a scart connection you are not going to get the best out of your tv and are going to be stuck with a standard definition picture.
