- Aug 10, 2019
- 2,556
- 5
- 0
I have been playing my arcydis dm1 speakers through my onkyo tx 8050 with no problems.so set up room 2 and tried to use my sansui 717 .if you turn the volume past quarter to the speakers start to get a crackle.thinking it was the amp I tried my sansui 417 and ran in to the same problem.so after changing the speaker cable and leads I still have the same problem.the onkyo is rated at 100 watts and both the sansui,s are rated less.so I have come to the conclusion that for some reason there is a compatibility problem between the dm1 s and the old sansui,s .but what the problem is is beyond me unless it just a power and impedance problem .can anyone shead any light on this or has anyone had a similar problem
