samsung le40c750 3d tv question?
markyboy156
203
hi how does the picture quality of the samsung le40c750 compare to tv's costing £1500 plus as you can pick up the tv for under £600 and its 3d could somebody please help me on this matter as i am after buying the 40 inch set is it worth it or could anybody recommend a 3d tv set for the same kind of money could somebody reply asap thanks
We had a 46c750 which had a very good picture. Probably slightly better than the Sony 46HX703 we have now. It has plenty of adjustments if your into tweaking the picture. One thing to point out is that it doesn't have any form of on/off switch. You can only put it into standby unless you turn it off at the wall. It does has a good BBC iPlayer app which also has the BBC HD channel.
