Samsung/Freeview HD signal drop outs
Hi guys,
I've got a bit of a problem with a Samsung TV-hopefully someone can help me diagnose the problem!
Its a 32" LCD set, about 3 months old. Very recently, whlist watching either BBC or ITV HD channels through freeview HD either the signal or the decoder drops and the screen goes totally black for maybe a second, then returns to normal. Everything is fine through non-HD channels or Sky. This has only started happening since the Freeview tuner wanted a retune. The Freeview HD is integrated with the TV by the way.
Any ideas?! Is it the TV or the Freeview? Cheers!
Hi there,
I had exactly the same symptoms. Mine is a two day old Samsung ue32d5520 set which is an LED Freeview HD one. I found that a firmware upgrade has solved it.
The TV couldn't find any upgrades via the internet connection or through the aerial, however on the samsung website there was a new firmware version available which I was able to install via USB stick (it took me a while to realise that you have to open the .exe file on your computer first to extract it!)
I found that I could check the current firmware version in the 'support' area of the menu.
I hope this works for you if you haven't already solved it!
