Samsung 48 h 6700 calibration.
Aug 11, 2014
Just a quickie for anyone out there,
I could do with some pointers about how to best use the colour space settings on this tv.
Ive played about with them but but without making much difference improving pic.
Ive got the disney wow disc but am not too sure how to get the best out of it,if that helps.
Thanks .
These colour space setting are for Professional adjustment. Having a Disney WOW disc is unless you have a meter to read a test pattern on the screen when adjusting those setting, your eyes won't see any difference but you will mess up the overall picture. I would set them back to the factory settings then get a professional to calibrate the TV.
The only setting you can really do your self will be Brightness, Contrast (even then a meter is more acurate) colour (if you have the red, green and blue colour filters, Overscan should be set to off (it may be called fit to screen, dot by dot and so on) Picture mode. This will be a personal preference unless you get the TV properly calibrated. Standard is usually the best but you may find Movie 1 or 2 to look more pleasing on a Samsung.
