CJSF said:Any one tell me if SACD format is Ok on a normal CDP, spacificaly, Rega Apollo-r latest half width version?
CJSF
MUSICRAFT said:CJSF said:Any one tell me if SACD format is Ok on a normal CDP, spacificaly, Rega Apollo-r latest half width version?
CJSF
Hi CJSF
Yes. Yes the Apollo-R also reads/plays back the CD layer of dual layered SACD's perfectly well.
All the best
Rick @ Musicraft
iMark said:I think most SACD's are hybrid. Most of the ones I have, have three layers: multichannel SACD, stereo SACD and Redbook CD. I have set our Sony BDP to play the stereo SACD layer because we don't have a multichannel setup. The CD layers have all been ripped into iTunes so we can transfer the files to our iPods.
Most of our SACDs sound very good, especially the ones from BIS (classical). We only have a few rock SACDs and the SACD usually sounds a bit less compressed than the CD layer. (Genesis, Peter Gabriel). Dark Side of The Moon sounds awesome on SACD though.
It's very hard to find out which masters were used for the different layers and of course remastering often adds compression.
I quite like the hybrid discs though. You can play the SACD when you've got a player that can play them and you can still rip the CD layer to your computer. If the stereo SACD has been made from a less compressed master, you could always record the analogue signal to your computer.
iMark said:Fortunately I bought a few excellent SACDs in the early 2000s, just before the format was dropped by Universal, EMI and Sony. In hindsight it was rather foolish by both manufacturers and record companies to drop the format. If every DVD-player would have had the capability to play SACDs and most discs would have been hybrid discs, the format could have been a succes. Of course the format war with DVD Audio didn't help.
Some of the discs I bought back then fetch rediculous prices in the second hand market.
Al ears said:iMark said:Fortunately I bought a few excellent SACDs in the early 2000s, just before the format was dropped by Universal, EMI and Sony. In hindsight it was rather foolish by both manufacturers and record companies to drop the format. If every DVD-player would have had the capability to play SACDs and most discs would have been hybrid discs, the format could have been a succes. Of course the format war with DVD Audio didn't help.
Still playing with the format as SHM-SACD I see so it's not quite dead yet (unlike DVD-A).
CJSF said:All I can say is, at £8.50, give it a go, or find it on the net and sample it, I could not find it on Spotify.
iMark said:CJSF said:All I can say is, at £8.50, give it a go, or find it on the net and sample it, I could not find it on Spotify.
Hans Theessink is on Spotify. It helps to enter his name correctly in the search box. *dirol*
I found the following albums: Whishing Well (2013), Home Cooking - Song Cooking Best of Songs (2012), Homecooking - Blues Cooking Best of Blues (2011), Jedermann Remixed - The Soundtrack (2011), Homecooking - Live Cooking Best of Live (2011), Birthday Bash (2009), Crazy Moon (2008), Songs from the Southland (2008), Lifeline (2008), Hard Road Blues (2008), Slow Train (2007), Bridges (2004), Journey On (1997), Call Me (1992), Johnny & the Devil (1989), Baby Wants to Boogie (1987), Titanic (1983).
