Running in
Hi all,
my first post so here goes.
I have just purchased a onkyo 606 and kef 3005se, at this moment i am waiting for the kefs to be delivered.
my question is does the onkyo need to be run in,and if so how long for and can i turn the amp on with no speakers or inputs connected to it?
cheers
neil
Don't worry - just use it once the speakers arrive. It'll soon run in with a bit of use, and so will the speakers.
Andrew
thanks for the quick reply. had a listen to the system at the dealers and it sounds great, can`t wait for the speakers.
Is it OK to ask where you got the Kefs, how much you paid, and what you compared them to before you purchased?
Jambutty1,
i ordered the kef`s from sevenoaks sound and vision £999.
i also listened to some b&w`s but they were just a bit too dear for me.
