Rotel series 06
Manufacturers website has made serious claims about series 06's performance. I have a few questions about them.
Is RA-05 / RA-06 a significant upgrade over RA-04? Quality-wise? Any differences in the electronics? Or is it just the transofrmer and the output stage?
RA-06, will it be same as RB-06 + RB-07 or better or worse?
Do you think they are a good value for money stuff?
Gregory, thanks! But I had three different question. You said yes is to which one?
hello ranjeetrain,there is not much difference between the the model numbers apart from power output as i believe.when i heard the 6 over the 5 it seemed a bit more controlled but not by much. for want of a better word, focused springs to mind.i have not heard the 4 so i can't comment but the one i liked was the 1062.so i suppose yes to all three i believe you will get significant upgrade over the 4.all thebest,gregory.
Thanks Gregory!
I would also be interested in knowing whether RC-06 + RB-06 will be better than RA-06 or same/similar.
Sorry about repetitive questions but this is because I can't audition them easily (need to travel over a 1000 mile for that).
From the page http://europe.rotel.com/series06/specs/rcd06.htm
The DAC used in the player is a Enhanced Burr - Brown multi-level Delta-Sigma DAC with 8 x oversampling with digital filter. Now, isn't that a very high profile DAC?
