Rotel RP-855 overhand adjustment
pixelandsoda
8
Does anyone have any experience in adjusting Rotel RP-855 tonearm equipped with Audio technica AT 110E cartidge? I have checked the turntable owner's manual, but the guide specifies the distance from the centre of the spindle to the stylus tip only...
Alternatively is there any specyfic alignment protactor you can recommend to buy or download?
Many thanks,
Download this after you have registered at www.vinylengine.com ...
http://www.vinylengine.com/ve_downloads/index.php?stupid_protractors.pdf
(Ok, it seems that even when logged in you have to download from this page ... http://www.vinylengine.com/cartridge-alignment-protractors.shtml )
... suits about 99 percent of all known tonearms / TTs.
Make sure when you print it the PDF is set to 100 percent and your print is set to 100 percent.
The protractor includes a reference scale of 180mm that you can check after printing to ensure it's correct.
Paste onto thin card and cut out spindle hole carefully with numerous pin ****** around it's perimeter or a scalpel.
