Roon
RoA
1,308
1,020
13,070
I have been a subscriber for a few years and would not want to do without it. Sure, it's relatively expensive but there is nothing that combines the versatility, functions and interface in a manner Roon does. Yes, there are other, free options, often suggested but they lack the sophistication Roon has. I also use the EQ functions a lot, especially with different headphones where individual EQ curves are programmable using it's extensive DSP and the resulting quality is fantastic. None of my headphones are used without. The AI for artist suggestions is great and cataloguing is second to none. Roon is also regularly updated but then you would expect this considering cost.
Are you using Roon and what are your thoughts?
https://www.whathifi.com/advice/roon-everything-you-need-to-know
I been using Roon for years i brought the lifetime subscription i am in complete control of my library which i like .
I used to use iTunes but got fed-up with iTunes changing things or missing album art but Roon is a good bit of software but expensive to buy .
