Room size limit with floor standers
macipod
42
Hi, I was thinking of purchasing some Quad 22L2 speakers, My room size is only 7ft -12ft would it be to small? If bass would be a problem would putting some foam in the ports help,also they would be about 30cm from side walls and about the same from rear walls.
I have a very similar room size to you and as you will see from my sig, I have a pair of ProAc Studio 130's and I am very pleased with the sound... no boomey base, tight control with a superbly clear top end.
Sugden A21L amp, Naim CD5XS CDP, Chord Cobra3 i.c. ProAc Studio 130 speakers.
I think there's more to it than just the size of the room.
  • wall/floor material
  • furniture
  • and maybe even the placement in 1st/2nd floor
