Hi i think i have an issue with my room acoustics. Basically i have had a room renovated in my home which is going to be where i listen to music and since the room has been freshly plastered my system sounds quite harsh i think. I dont plan on adding lots of soft furnishings therefore I plan on now having some walls refinished with a 6mm soundproof wallpaper product in an attempt to calm down the harshness within the room and sound transfer to an adjacent room.
My questions are as follows:
Has anybody used a soundproof liner before?
Can i put this on the wall directly behind my speakers?
What are peoples suggestions towards calming harsness down?
Are there any ways i can tweak my system to reduce the harhness?
And is there a difference between harshness and brightness?
I apologise for all the questions in advance. I can show pictures of the room if it helps, the room is approximatley 4m x 5m with wood flooring.
