- Jan 1, 2015
- 22
- 0
- 0
Hey everyone,
I am trying to figure what differences the new Roksan K3 integrated amp has compared to the older K2BT? To me the new K3 obviously looks nicer, better built and more elegant from the outside, it also has a new remote control, but what about the differences on the inside? Parts? Anyone compare them on sound quality?
When reading the description of both amps they appear to be very similar. I did however find two small differences. The K2BT uses a 500 VA transformer and the K3 uses a 550 VA one. Wonder if it is still sourced from Nortel? Curiously they are both rated at 140 watts into 8 ohms but into a 4 ohm load the K2BT puts out 250 watts where as the K3 is putting out only 220 watts.
I am thinking about buying one. I know Vladimir will be proud of me if I do 🙂 Here in the States the K2BT sells for $1900 and the new K3 for $2500. The K3 sure looks better, but if it sounds the same as the K2BT then I don't know if the $600 price differential is worth it or not. I have a feeling I won't like that stubby volume knob on the K2BT though. Looks irritating.
