Hi all,
I'm new to the forum, and moving into high res audio, so would like some advice please before purchasing.
My primary objective is to move away from an iPhone/apple headphones and migrate to cd quality, or high res, via a DAP.
After listening to Tidal on an Astell and Kern SR25 mk2, with Meze classics, I was quite impressed. The cost of £850 is just about in budget. I'll probably use Apple Music high res though due to an existing subscription.
Workflow would be to rip on an old MacBook Pro using either XLD or dBPoweramp (is one better than the other?) then copy to the AandK. My CD library isn't huge, so I'm not concerned about file but would appreciate advice on the best format for quality. Is it WAV, AIFF, or FLAC? I'd maintain 44.1/16 rather than upscale.
I may choose to output the AandK unbalanced into my existing hifi ,and I presume it's DAC will be far superior to a MacBook Pro headphone out.
If I upgrade my amp in future to possibly something like a Quad Vena then can I connect the AandK via USB?
https://www.richersounds.com/catalog/product/view/id/19338/s/quad-vena-ii-lancaster-grey/
All thoughts/suggestions greatly appreciated.
Cheers,
James.
Cheers,
James.
