Hi all. From another thread some of you will remember that my CD player (CD6002) had died and needed replacement. I went off to a demo to listen to its nearest equivalent in the range with as close as i could get to my system (Ra-05, RA-10 tested) and B&W 685 speakers. I also wanted to listen to a better CD player with my system and a good mid range option in case of a full upgrade. The Marantz CD6005 went into the trio of RA-10 and 685 and it sounded lovely. As dynamic and powerful as my current home system but with more detail and separation. I heard instruments, mainly around the drums and especially the hi hat and cymbals that i had not heard before. We then swapped the CD player for an audiolab 8200.
This was an even better listen, just as powerful but even more detail and the cost difference was justified. Running out of time there was just enough time to listen to a "dream setup" the audiolab, a Roksan Kandy K2 and the Kef LS50 speakers. What a disappointment. Plain, dull no sense of power, no treble and lacking in bass. In case it was the speakers we put the 685's back on and it still sounded poor.
So it seems i like the Rotel style of amp with the bass and tonal quality from that and the 685's. With this in mind which other amps and speakers should i try in a mid range system to most compliment the audiolab assuming that better can be had than the base Rotel or will the LS50's sing with a better amp? Or indeed will i not get the expected increase in quality without losing the punch that i currently have I'm going for a second demo tomorrow so your thoughts are welcome.
