resga RS5 versus monitor audio BX5s for Cyrus amp
Nck_D
I'm looking for some new speakers for a 2nd hand Cyrus system I have recently purchased:
8vs2 amp, PXR-s and a CD8x cd player (not currently recognising discs!).
Basically I want some fllorstanders but in a smallish room in alcoves either side of a chimney (so they'll be close to a wall).
These both fit the bill in terms of size, price and quality.
I recently audioned the MA BX5s - had good bass, and sound, a little less bright than the regas (and others i've auditioned) but apparently not good against / near walls
Rega RS5s (on special at £600) in a different shop but also seemed brighter but lacking in bass. But could be used close to walls.
The Rega had big side cones so i was surprised by the bass; and it was in a much bigger (nicer) audition room than the BX5s. And other reviews don't seem to suggest a lack in bass. The MAs seeemed ideal but worried about close to walls.
I listen to an ecletic mix so it is better to be a jack of all rather than a specialist in one.
Has anyone had any experience with either speakers to suugest one above another.
I am a Monitor Audio fan. and suggest you go with them and put the post bungs they supply in the rear ports. I have done this with some RX6 speakers and they work fine. The front port serves the bass speaker and the rear port the bass midrange speaker.
