- Aug 10, 2019
- 2,556
- 4
- 0
Hello all,
A bit of advice if you would, to a relative non expert.
After many years of service, my Rotel RA-01 amplifier is on its last legs, is dying and needs replacing.
My speakers are B&W DM 602 S3's, CD player Rotel RCD-02, I will not be replacing these. Combined with my current Rotel amplifier, I have been really happy with this set up.
My question is, should I play safe and stay with Rotel, from what I have read, and indeed heard in my current set up, Rotel and B&W compliment each other well.
Or can anyone can suggest a good alternative partner for my B&W's?
Budget of around £500 suggests the Rotel RA-06, although, for example, I have seen a Rega Mira 3 for £400
Would really like the Rotel RA1520, but £700 is stretching the budget a bit..
Many thanks
Many thanks
