replacement cart for ariston
Hi all
i would like some suggestions for a replacement cartridge for ariston rd80 with linn basik plus arm. current cartridge which came with the tt is linn k9.
i want to change cartridge to get a little more from the tt as when i compare the tt to my cd the tt sounds a little restrained can i improve or is this the best it will sound.
not sure of age of current cartridge as came with tt so maybe its worn
Thanks Darren
What sort of budget are you looking at Darren?
For up to £80 I would be looking at the Ortofon 2M Red, up to £150 the AT-440ML.
Both have the characteristics you are looking for - and both will be loads better than the K9, which will have had it's day now (both from a design point of view, and the fact that the suspension will be hardening due to age).
fatboyslimfast
dont have a budget really not sure what the limit would be for this tt £200??
I would say definitely go for the AT-440ML then - it will give just the sound you seem to be after, and I would say is about the best the Basik Plus can handle.
It also digs loads of detail out of the vinyl, even if the vinyl is a little worn.
Sound Hifi are doing them for £125 at the moment - a very good price and I don't think you'll better it sub £200.
