Hi thartog and welcome.
It's always difficult to advice what is right for you, in your specific situation. What is good for you is not always the same as the forumwriters will advice you to do (if they stay on topic *wink*)
BTW, is your budget in euro's?
Wireless can be great (Sonos, Kef X300a, Geneva model M, Noonday, B&W ) but they all need power so it is not entirely wireless.
You mentioned that wired is also an option. With wired stuff you have more to choose and you can do two things: put a lot of effort in it to make the cables disappear or exaggerate with fancy cables so they are a visual part of the system and your livingspace.
If you choose for wired there are great amp's and speakers for the budget. Like a NAD D3020 with some B&W or DALI speakers. I've read some interesting reviews over Highland audio ORAN. Nice floorstanders with great sound.
But go and have a listen for yourself.
In the end, if you have 80 euro's left on the budget, you can buy a gramofon-set to make your speakers connect with wifi so you can sit in your loungeset with a glass of wine in one hand and your phone in you other hand so you can choose your music from there.....
