Removing smoke odour from equipment?
JohnDuncan:Clare Newsome:I've also heard that placing kit in a box with some activated charcoal (eg cat litter!) can helpActually, I've been meaning to ask how to get cat poop off the Uniti...
Are you thinking that they won't want it back if it has **** on it?
JoelSim:Are you thinking that they won't want it back if it has **** on it?
Not if the cat/stomach bug/rented television experience is anything to go by (thank you Radio Rentals).
Chebby; if you live near a Wilkinsons you should be fine (other retailers are avaliable).
Wilkos stock a fair few Astonish products. They're very good; we (wilkos) use their cookware cleaner to clean shelving etc.
To my knowledge, a 'closed cell foam pad' is basically a magic eraser (http://en.wikipedia.org/wiki/Melamine_foam), which is very soft at a macro level, but has hard edges at the micro level.
Interestingly, some websites recommend (I haven't summoned up the courage / stupidity to try this yet) magic erasers as stylus cleaners, where by the stylus is just lowered onto the foam, or a very small section is moved in a linear fashion front to back.
I'm a little sceptical about that, but their cleaning power is undisputed.
